Still Trying to figure out why the overdrive was not working [?],
on checking the oil level , Milky oil dribbled out ,
Van has been laid up since we came home ,which it managed ok without the o/drive working .
Added some coffee and sugar and still better than Jim's brew's [)]
Perhaps the gearbox/overdrive was top up with some sort of oil that is not compatible or reacted? I have seen engine oil turn to jelly or go like tar just from mixing with another brand or type oil. Just a thought...
Are you sure its water related? Could be the clutch lining of the od breaking down. Also check to make sure its not alloy particles from a mechanical issue
Replaced the oil a year ago. It has worked and wasn't slipping in the past. But stopped working after I didn't use the van last year. But can ofcourse be that the seals are one the way out. Seal kit isn't expensive and rather easy to replace.
Did you already start to fit the SU kit or will you keep the solex?
Hello David,
van is running great on the original solex ,
just waiting on dvla [xx(] sent copy of original bill of sale , to help my case to get the number back.
will try the seals after I change the switch [?],
They usually are There are a few different types A,D and J types, all basically the same but with a few differences like solenoid construction and percentage increase in final drive.
