Meet Ted
Spiffing good news old boy! .....my only gripe is! ...who got 'old english' on the tyres? :I
Member of The 6-Speed Club
Nah it's not paint - just the soapy stuff they use when fitting a new tyre:)
Harvey & Bonnie
:D:D[8D] ........they coulda put da weights on da inside:D:D ......yes, I'm nit- picking, but, thats what one does when one is faced with judging such perfection :D[8D];)
Oh I say Sir! Rather good.
I fitted one of the intermittent wiper robots to Ted a couple of weeks ago, it worked but there is a bit of a strange thing going on. The wipers flick away intermittently as they should but when the indicators are switched on it seems to interfere with the timing of the wipers - every time the indicators flash the wipers try to sweep :I. This also happens occasionally when the fuel pump clicks. All I can think of is that there is interference as the other equipment operates that causes the relay on the new board to kick in, I wired the feed to the fuse board but if it's connected direct to the battery the intermittent system works better:I. We went out in Ted today and had the first real chance to test it properly but the system was a bit more intermittent than it should be :( The lowest timed sweep should be five seconds but there was hardly any gap between it kicking in and on the longer times the wipers were stopping half way across the screen then completing the sweep on the next click of the timer. Something had to be done. I salvaged a capacitor from an old computer power supply it was a 50v component as compared with a 25v one supplied with the robot kit so should be more reliable. So stripped the PCB out from behind the dash and replaced the capacitor - it was awful [xx(]( The wipers were stuttering as the relay on the board clicked away erratically and the system became unusable (faulty salvaged component maybe). So I pinched the capacitor out of another kit that's waiting to be fitted to Harvey and fitted that - result :) Although there is still interference if The live feed is taken from the fuse board the robot does it's stuff perfectly if taken from a permanent live feed taken off the voltage regulator. That'll do for now :)
A little bit of staining on Ted's timber has spread a little[V]
As I don't have any wood welding rods these got dusted off and sharpened:) Where do you plug them in;)
A bit of poking around.........
....developed a bit:I
A little bit more than I anticipated but luckily I've got a piece of ash big enough to do the job. All the cut ends have been given a couple of applications of Cuprinol and tomorrow I'll knock up the repair pieces :)
It's OK - I've just snapped some off the silver birch, they should work with the right flux:)
Originally posted by renaultvation
What sort of joint are you going to use?
what sort of weld are you going to use?
The rail joint will be scarfed and I'll re-create the tennon on the rear pillar, been doing some of the preparation today:)
The waist rail molding is a bit more complicated than I could manage with me chisels so I've joined the router club, first time I've used one and it turned out quite well[^]
The original section is on the right, with a bit of planing down the new piece should be fine.
First bit of new wood glued in
Trimmed off and the rear pillar repair temporarily in place
Sloshed a load more Cuprinol on the new wood, tomorrow should see it all together and shaped:)
That is a cracking good job you're doing there Panky. I too, noticed that you had lined up the grain. Did you have much ash to select an appropriate section, or was it just good fortune?
The piece I had was 600mm long and 70mm square and I've got a hand full of shavings, sawdust and little offcuts left - good fortune indeed:) But I did have four sides and two ends to choose from;)
Nice repair Panky, a few coats of varnish and it will be splendid ;)
Didn't quite get as far as I'd hoped today as all the joints need to be treated with Cuprinol before final gluing and assembly and it needs to dry overnight but here's where I got to.
Roughly shaped the pillar repair section, it's held in with screws from the inside so I can remove it knowing it will go back in the same place.
I made a template off the other pillar to get the position of the tennon.
A bit of sawing and chiselling later
Tomorrow it's time to get sticky:)
