Hi guys. Sorry Ive not been on much. There has been a lot going on recently. Im now single and have very little time to sort the van out so heres an update.....
I rebuilt the top end of the engine and got approx 200 miles before big end failure! It spun the shells of cyl 2 and locked the engine solid. Martin came up trumps yet again and supplied a nearly new crank and a new set of big end shells, main bearing shells, oil pump, and the facilities to do the job! She was running OK until she sucked water out of the fuel tank, I drained the tank, pipes and fitted a new filter. The carb was also stripped and cleaned.
She then started misfiring and popping, cutting out etc. The points were found to be at fault!!
400 miles down the line she is running spot on but has developed an oil leak from the timing case, the jobs keep coming!!
