Kermits V8 conversion
Ha ha ha that means I can pull away in 5th lol
GOD DAMN IM MISSING MY VAN.
BUT IT'S GOING TO BE WORTH IT
Nick the video makes it sound loud in the cab but its not that bad but its much louder than the video on the outside of the van it makes your chest vibrate .. I love it
Just watched the vids - [8D]:D:p
Gearshift pattern now reversed, so hopefully we won't be pulling away in 5th now :D.
Fuel gauge is now working.....................................backwards :I:D:D:D:D:D
WONDERFUL!
Although that whistling noise detracts from pure V8 noise [:p} (not jealous!)
Brilliant - you actually make fuel as you drive:)
Gear shift was an easy fix - just turned the gear knob around;)
No, i turned the drivers seat around :D
Yep, the further you go, the more it fills up, just a bit disappointing when you pull out of the services with an empty tank ;):D:D:D
Ouch...you'll have to mind you don't slash your wrist when checking your oil now Dipstick Rich:D:D:D
Another step closer :p
Just need to mix it and fill the tank now [}:)]
h-armstrong-roberts-mad-scientist-in-laboratory-mixing-chemicals_i-G-56-5632-N32MG00Z.jpg
Water/methanol tank now filled up :p it holds 10L.
Following Bernie's lead we added a touch of class with this Mercedes booster pump for the heater ;)
And some pink red padding for the cage :D
