Just had a thought
Not any longer, sold it at Christmas - kids grown up, wife wants a proper holiday (another reason why no Commer yet). :(
Having withdrawl symptoms following sale of boat, so am currently making radio control model! [^]
Wasn't Lancelot experimenting with a coil in a modified water tank heated of the engine?
We had a chat about this at one of the meets - I think the plan was to run the water from the rad through a coil in a hot water tank, with a shut off obviously! To me it sounds like a very simple way of making life on the road that bit more comfortable!
would be nice to turn the wardrobe into an airing cupboard [^]
I do use hot water in Ran....just boil a saucepan:D
FAO Chris & wife how about a proper holiday in a COMMER you could add port holes etc ummmmmmmmmm :p
"RAN"the van FORSALE. "SYBHIL" & N0.1 Probably won't get restored unless I win the lottery.
Thats a good name for a commer :D[}:)]:D
only kidding [}:)] you can go abroad in a commer too not that I have been that brave,not yet any way [}:)](I don't think I can stay in uk for much longer getting way too expensive :(
i've done that on my commer but put it in the rear in one of the seats. used a heater matrix from a nova and some pc cabinet fans (really quiet), makes all the difference. helps the engine stay cool and helps me stay warm. Inspired by this http://www.xor.org.uk/unimog/mymog/waterbox.htm
WOW thats great [^] what sort of cost is involved diy [?]
Originally posted by BigMonkeyMan
Eco-mmer! Jules what was the problem with vibration? did it keep cutting out?
Sorry I can't help with the spam stuff, in fact I'm pretty rubbish when it comes to webby things (my website was my only really attempt and that's just a blog now!) I'm more of a physicist/programmer and only really learn stuff that is relevant to the job I'm currently doing!
StudioCommer, I'm pretty sure that the extra wind resistance that the turbine generates will be equal to the increase in fuel consumption!
Rupert
www.littleyellowcar.co.uk
It didnt so much cut out as degrade according to the metre. Also unless exterior mounted I dont think theyd catch many rays in a commer
Originally posted by renaultvation
We had a similar system on our boat. The engine coolant went through a coiled pipe in a domestic hot water cylinder which provided hot water which meant we didn't need to use the gas boiler if we cruised everyday. I have seen a similar system on some hire boats which also serves the central heating. They reckon to get about 6 hours heating on a 58 foot boat. It must have a much larger storage tank. I don't see why the system shouldn't be scaled down for use on a Commer, although you will have to be careful you don't overcool the engine. ;)
I dont really want to run engine coolant all round the van as I usually have enough probs with simple hose plumbing which have to be there to cool the engine. If something spring a leak it would be a breakdown.
But I do fancy free heat from the exhaust to the back of the van. So I can run a copper coil heat exchanger round the manifold and another as a gainful heat sink in a cupboard or somewhere, & install a pump.[?]
But any ideas how I stop it boiling & bursting?
My PA had a second radiator and fan in the back of the van (in the cab) to double as extract cooling when in traffic and a bit of warmth in the winter.
TV detector has a second heater matrix behind the drivers seat. Hot air is then blown round the rear :) I have a spare, so may fit it in another van :p
sounds very similar to what came out from under P5 rear seats - takes a copper feed from cooling system with a blower.
hi jules. a calorifier is only a hot water cylinder like in your house http://cgi.ebay.co.uk/eberspacher-water-heater-tank-with-fittings_W0QQitemZ150244047820QQihZ005QQcategoryZ15263QQssPageNameZWDVWQQrdZ1QQcmdZViewItem they do not have to be expensive. and if you want to keep the water seperate from the coolant you could use a plate exchanger which is very small and extremley efficient http://cgi.ebay.co.uk/Ideal-ISAR-Boiler-HE24-Plate-Heat-Exchanger-Kit-New_W0QQitemZ310047741729QQihZ021QQcategoryZ42234QQssPageNameZWDVWQQrdZ1QQcmdZViewItem although this particular one would be difficult to install, if you are interested i have one in the garage you could have.. as far as the water exploding you have two options, either use a safety valve to discharge any excess water or a small expansion vessel or a header tank.....
just thinking, would the hot water circuit also need to be protected from freezing ? So coolant water would be a good thing ?
