Latest update for Jog. Not used him since Pandy, and have since stripped and rebuilt the carb, replacing the needle valve and float to try to get an improvement on 19mpg.
Was going to take him to the Uxbridge autoshow today, but this was cancelled - but took him up to Ealing instead, where is spent the night in an underground car park. This morning we went over to my brother's house for an introduction to my car mad nephew. Jog was a big hit. Every switch was turned on and off, cupboard opened etc, and then we had tears when it was time to go.... well, he's only 2
However, the best result of all was when I filled up just before getting home, having done the same when I left yesterday. Did a total of 76 miles, mostly on motorways and dual carriageways at between 55 and 60 mph, and the total was 11.75 litres - which works out around 30 mpg. Not a bad improvement. The timing needs resetting - there is a lot of popping on the overrun, but will do that when I fit the new rad once it's back from being recored. Coming soon is a rewire, electric rad fan, new hoses, electric fuel pump (still not fitted but currently awaiting a pressure regulator), leisure battery and electrical hook up - and a fridge if I have time. All this needs to be done before the 24th August, when I will be heading across the channel for a tour of the Alps with Ruth.
A
