Jog the Wanderer
You can just go for the points conversion. I chose to change the distributor too as it's not too much more expensive, and at least you get rid of any wear in the dizzy shaft. The guy in the shop said that for most cars, the advance curve isn't that important - especially if you are not looking for high performance. However, you can always swap over the weights and springs from your existing dizzy. But I like new shiny things, so I bought the whole lot. Only cost £70.
Originally posted by paulcloke
wow that not bad. what are the engines prone to problem wise?
starting [}:)] joking:D they are quite bullet proof little engines really:)
cool, seem to remember alot of breakdowns when i was a kid, but dad seems to think they were all diesel ones he had probs with lol
Originally posted by Enigma
so, i know its been covered before, but do you use the new pump instead of the original? ie, bypass the old pump? or use it in conjunction with??
It,s one or the other Colin, you can,t have both on the same feed line :)
Part one completed. Fitted the distributor and coil, tidied up some wiring and replaced some horrible crimp on terminals that I detest. While I was there, the oily side of the engine got a blast with my engine degreasing gun filled with paraffin. So, the distributor side of the engine is now nice and clean. Happily, the engine started first time, and now idles nice and smoothly. I am very pleased. :)
Part two, the fitting of the electric fuel pump will be done next week, once the mounting kit has arrived. I forgot to order the bobbins when I ordered the fuel pump. All I have to do now is source some suitable nylon fuel line, and decide where I am going to position it. I have a rivnut fitting thing, o will be fitting it using this method.
I will be bypassing the original fuel pump. I guess I will leave it in place as I don't have a blanking plate.
Andy
Iirc its the simon bbc ebay seller who says not to use
sports coil with his electronic ignition!
not sure what dizzy andy has purchased.
The Colonel Mustard
The Colonel Mustard
Mine is the Accuspark dizzy, as seen on eBay, classic car mags etc.
http://www.accuspark.co.uk/
A
I used the exhaust bobbins off a Mini to mount mine. That was about 12 months ago and still haven't got round to piping it in:I
Two's company
Will you please leave the Mini alone there will be nothing left soon :(
Gladys :)
Its best to remove the manual pump if your not using it as you will release an extra 2bhp of sheer power! You can easily make a blanking plate from a piece of steel.
In that case, I think that a blanking plate is soon to be manufactured. I have one for an Imp. I wonder if that would fit? Those extra 2 horses might come in handy for some of those climbs I have planned for Wales in a couple of weeks . :p
As Panky says you can just remove the operating lever, I dont think the blanking plate from an Imp will fit the Commer, If my memory is correct the Imp pump mounting is narrower than the Commers.
Well, Jog and I (and Ruth) will be going on holiday at the end of August. The destination - Southern Germany, Austria, Lichtenstein and Switzerland, maybe with a bit of France.
Ruth parent's live between Strasbourg and Freiburg (on the sausage muncher's side of the border) and will be looking after the kids for her for 3 weeks, so the plan is to meet her at near Munich and then do a little tour of the alps and then head back to Freiburg for her to collect the kids and fly home with them (back to Barcelona).
So, I have a list of things I need to get done before I go:
  • Fit electrical hook up and leisure battery.
    Fit 4 new tyres, preferably on refurbished rims.
    Fit OD gearbox.
    Replace wiring loom.
    Replace Radiator, all hoses and waterpump.
    Fit electical fan for rad (essential for going up mountains)
    Fit new water temp gauge
    Sort fuelling issues (in hand)
    Repair awning
    Fit fridge, or provide connection point for coolbox
    Fit decent radio/mp3 system.
So, that's a lot to do and I have 3 months to do it. Will Jog go on his holidays, or will Goldmember the Berlingo get the call? Stay tuned to find out....
A
Latest update for Jog. Not used him since Pandy, and have since stripped and rebuilt the carb, replacing the needle valve and float to try to get an improvement on 19mpg.
Was going to take him to the Uxbridge autoshow today, but this was cancelled - but took him up to Ealing instead, where is spent the night in an underground car park. This morning we went over to my brother's house for an introduction to my car mad nephew. Jog was a big hit. Every switch was turned on and off, cupboard opened etc, and then we had tears when it was time to go.... well, he's only 2:(
However, the best result of all was when I filled up just before getting home, having done the same when I left yesterday. Did a total of 76 miles, mostly on motorways and dual carriageways at between 55 and 60 mph, and the total was 11.75 litres - which works out around 30 mpg. Not a bad improvement. The timing needs resetting - there is a lot of popping on the overrun, but will do that when I fit the new rad once it's back from being recored. Coming soon is a rewire, electric rad fan, new hoses, electric fuel pump (still not fitted but currently awaiting a pressure regulator), leisure battery and electrical hook up - and a fridge if I have time. All this needs to be done before the 24th August, when I will be heading across the channel for a tour of the Alps with Ruth.
A
That's better[^]
Harvey used to pop and bang on the overun like AAA. I found he was running a little lean:I
How refreshing
