J overdrive
I’d take a look at this thread on a Triumph site.
I don’t think have ever seen a wiring diagram for an overdrive on a Commer PB. There may be one you can adapt form a Triumph or other D Type fitted period vehicle.
I fitted a D Type overdrive with a relay via a gearbox inhibitor switch on reverse gear so it won’t engage in reverse but will work on all forward gears. Just needs an on/off switch on the dash somewhere to operate it. Plus I added a tell tale light.
Good luck with yours.
Thank you for the information but no luck getting it working there must be different wiring for the j type Reg
See if any of these will do the trick. Are you using a relay or wiring the live feed direct to the solenoid?
Ignore the wiring colours it is not not Commer wiring.
