I'll soon be boarding out the rear of my Commer and very interested in what others have done here.
Firstly, I'm intending to apply cavity wax in all the nooks, crannies and seams etc. and then use marine ply (sealed with a waterproof coating) to cover the rear floor and sides.
Some insulation on the inside of the marine ply seems to be what others have done but apart from seeing some using foil costed bubble wrap type, is there a preferred type/brand of insulation for this purpose ?
For the floor, is it advisable to run some battens across the pressed ribs and lay the ply on that (insulating between these batten 'joists'). Or use thick enough ply to support itself and stick the insulation direct to that - but what will the insulation compress over time and introduce movement ?
