if you google it , it states blue flame good gas/air mix orange flame more gas than air mix and its not burning the methane properly dont know if this helps though:I
probably down to the fact it has not been used for such along time why not give it along burn with plenty of ventilation and see if the pipes clear themselves[?]
Will the burner lift out so you can clean it? some burners unscrew. Incomplete combustion usually caused by not enough air mixing with the gas, or to much gas.
The fridge works fine on gas but i want to be able to run it on electric too...the fridge has 2 wires, am I right in assuming one is for a live feed via a switch and fuse box and the other is just an earth??
cheers Charlie......yeah, I managed to clean the oven and thats ok but.....i tried to adjust the mixture for the hob and both of them were so rusty they snapped off...so been hunting for a 'new' cooker////like needles in a haystack
