Drip...drip...drip...
what psi ? radiator cap have you got higher the better just put a 15 on The Colonel because he keeps throwing up from the over flow pipe :I fingers crossed that's all that's wrong :)
The Colonel Mustard
If I top the rad up to just below the filler neck it will blow the coolant out until the level is about 1/2" above the core, and it stays there:)
Summer's here.....
Told you
I do that too but he spews to below the core [V] I think the new cap might be 21 psi
The Colonel Mustard
Currently a 9 LBS cap.
The level used to settle to around Panky's, I think, but now continues down past the top of the core and onwards with no noticeable leaks and no drips anywhere[V]
Out of interest what car does the higher pressure cap come from.
Summer's here.....
Told you
true jules I had a header tank on my 3 wheeler :I
I knicked it off the mini [:0]
but bought it from local motor factors took the old one with me.
The Colonel Mustard
More slack than the bottom of the coal hole. I think it needs some love.
Summer's here.....
Told you
Funny you should mention the radiator, Andy, because we dropped on this unused and dusty one at Weston Park last week, measured up not identical, but will fit if needed.
