Managed to remove the build-up of crud in the water jacket, below the core plug and between cylinders 3/4, with a made up scoop and wire then flushing out with plenty of water.
Anyone know if this much is normal then[?] (and some got washed away into me lawn:I)
No matter how much you poo get out there always seems to be more[V]
Keep flushing, if you haven't already replaced the core plug then stick the hose in the hole and swill it about.
Nice one Greg. Harvey was still running a bit warm even after a good flushing so I gave him the Radflush treatment. This shifted even more poo and did improve things but even now the coolant is still a bit brownish:I
Finally re-fitted the gearbox again and all the rest of it and returned shot clutch cover to Speedy's for restoration.
Even remembered the spot of grease on the flywheel bush
Round the block and the clutch action/feel is great. Along with a steering/suspension grease-up whilst laid-up and she's bang on again[^]
Then this happens[xx(]
Phew, only snakeskin on the fuel filter, easy clean
However, I only cleaned off the filter and replaced the cover, honest guv
Started up, reversed off the drive and engine stopped, refusing to restart on cranking
Rolled back onto drive and after a short interval returned and she fired up and behaved for a nice 25 mile round trip in sundays heat
Checked the filter again today and replaced the cover....same problem
Theres petrol in the tank but none coming through here[xx(]
