CRAP WEATHER heater project
Jon
0
As the smow seems to be hanging round and the workshop is stupidly cold I thought I would do something about it. I brought a parafin heater the other day from an farmer who had it fitted in his big farm house. After I stripped it all down cleaned it and re painted all the insides with heat proof paint.
After i had a big move around to make a place for it with stuff everywhere
I fitted the flue in and had it goin for a while but it just didnt feel hot enough! lol
I added a feed pipe to use waste oil gravity fed from the loft
I decided to try turboing it;)One to get it hotter and to to make it burn super clean,which it does:D:) Once its up to temp there is no smoke at all. I made a conecting piece and put a tube inside the burner to fit my heat gun on but set it to blow cold. It worked a treat, but needed something more permanant,thats were it had to contain a bit of commer so I used a commer heater blower and fixed it to the wall next to the flue.
Heres a video if it works,did a few mods after this run:
Needed a better way of controling the flow of oil so came up with this
Its that hot in the workshop now you dont need your coat on;)
A commer with even bigger boost will be appering on a screen near you soon!
Here is the video
http://s233.photobucket.com/user/commerjon/media/BC5D4B96-3FA6-475F-B89B-A09675183B7D-2639-00000471ADF2F5C6_zpsc1dfa1fa.mp4.html
Nice old bit of kit [^]
You're going to need a swarf guard though ;)
Originally posted by Panky
Great idea to use waste oil[^]
