Commerjules
All sorted now.
And even uncovered a boarded-in fridge while I was at it [:eek:)]
Look forward to seeing everyone on Saturday.
Got a few questions about the new headlights at the Spring meet. So here are the details if anyone is interested.
I found that the standard sealed beam units are not very bright. So I changed them to halogens. But then they didnt look right as too modern as you could see the bulb. So changed them again to P700 types with the tribar. And added a pair of eyelids for good measure. As they also incorporate a sidelight facility when the van is repainted I may also do away with the sidelights and just have the indicators for a smoother look.
How much and where from for the headlights?
Percy has got Halogen headlights but one has got a tide mark from water in one of them and could do with a change
Percy-1975 Highwayman
Originally posted by commerjules
http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Headlamps
:D
Thanks
We have to look these up when I can afford it (now found some rust)
Got my speedo cable back from Speedy Cables
They took 2 weeks and charged £43.59, which was somewhat more than their estimate in terms of both time & money....
Jules,
I'm wanting to setup a similar intake for my standard carb (without the filter fan), so I'm curious what you used for the ducting and tips on how you finally routed/installed it all.
BTW : I'll also be changing the exhaust to cope better too !
Paul
Can I pick up on some things said earlier in this thread?
I have both the original belt driven fan and also an electric fan(fitted to the front of my radiator). I have always been suprised that the temp control hardly ever goes past the lower temp red section (left hand side of the dial face), even when climbing long gradients. Having read this thread I am think of unbolting the belt driven fan from it's pulley and leaving the cooling up to the thermostactically controlled electric one.
Should the temp reading normally be higher than I am getting and if this "is" the case should my fuel economy also improve (warmer engine and all that)?
Any thoughts welcomed.
Ruairidh
yes, a hotter running engine will use less fuel(at the expense of power)it could be that you have the wrong temp sender fitted, giving a low reading. but assuming its correct then take the mechanical fan off and give it a try :)good luck ;)
Paul:
I just used some ducting that I had. Sorry I dont sell it.
My exhaust has changed again (as debuted at the spring meet) I will post details if anyone interested
Ruairidhdunford:
Yes a hotter engine uses less fuel, but furthermore shouldnt develop less power as long as you keep the intake cool (which I have tried to do with the ducting and remote fan assisited filter etc) - colder air is denser air therefore more O2 per CI. But much more than this is that you will liberate power that was wasted driving the mechanical fan - 3 extra horses for free on my motor.
Have you got any pics and did you use the commer downpipe off the commer manifold?
I think the details are earlier in this thread. Or search the forum for exhausts or cherry bombs or something like that for everyones comments
Yes Please!
Basically I wanted a freeflow exhaust for the open road (there's one left in London), but I also wanted a quiet exhaust as I didnt want to annoy the neighbours too much. Now at the flick of a switch I have either. Sorry to sound smug [8D] but I am quite please with this mod
http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Exhaust_Cut_Out_Valves
mmmmmmm having borrowed a nice Audi RS4 for the Easter weekend and experienced its "S" (for sport or smile button) this would be brilliant on a commer.... with 420 bhp of course
