If the shimming doesn't work the plate may have stuck to the flywheel, try putting it in reverse and crank it over - it works sometimes if it's not too badly stuck. Or get the engine warm, stop it then see it you can start it again in fist gear and slam on the brakes on when you get a little speed up without depressing the clutch, drastic but again it does work.
Summer's Coming
Summer's Coming
