For nowYou staying stock Paul?
Good point.The only problem with that is that the brakes need heating up before they work properly which you probably won't get under normal driving ( I know you're not normal) And running at those high temperatures will cause brakes fade - unless you switch to silicon fluid. I've heard quite a few reports of people fitting the uprated pads only to find the brakes where rubbish when cold. Maybe fitting a servo would be the way forward.
Jon had some a while backNot sure they’re ready yet. Imkeep
Looking for the Hawk stubs, just missed out on a pair from a scrap yard when I found the 4.22 Diff - gutted
Will do mate. Have contacted a local placeThe old 'green' AM4 material used to be useless until it warmed up, but AM3 or equivalent is still available. Best speak to a brake relining specialist.
