Thought I would give you guys an insight to the project ive got going on with my commer I got in July.
Heres some of the pictures of how I found her.
This is exactly what I ended up doing, I still need to route the wire properly but everything is now working wiring wise apart from my washer jets but I’ve got new tubes on order then will get that sorted. Mission complete really, next task is to build some sort of platform within the dash for my fuse box to live safely with easy access. Still haven’t sorted the hazards yet as I blew the flasher but will get around to sorting that later down the line once I come to tidy the looms. Next mission is to paint the engine cover and under the seats and floorWorse case can you run a negative wire from the battery to the bus bar?
Yeah that’s what I took this bit off from, unsure if I was supposed to I’m assuming once I’ve put the new one in I can just put the pipe onto the new one.There's usually a red tinted plastic pipe from the master to the slave and that tail pushed into it - as in the first pic.
Diamond would appreciate that, I think the only way to solve the issue is a new line, I went under her again today and no leaks from the master it’s all leaking at the end of the line where it goes into the metal thing see attatched. I think it’s just that my hard red tubing is shafted and it’s supposed to be put on with a special tool and this just slides on but not tight enough clearly.I guess any would fit that’s long enough and has the correct fittings. Assuming they’d be a BSF thread both ends. Think I have an old slave cylinder and a box of bsf bolts. I’ll try and measure it for you
