Hi,
Its been quite a while since I touched the Commer, but at least it is housed in the shed, which has a roof!!!
Found a few minutes today to finish making the repair sections for the side panel tops on the drivers side so I can fit the new gutter sections. Basically another 3 or 4 of these:
So I can continue this repair all the way along ready for the new Gutter section:
I am hoping to find some time tomorrow (friday) to get the welder out and get them welded in. Then I can see if the same is required the other side, sort the rear cones and door pillars out and then it is ready to put the replacement roof section off Green Bean. Sounds easy, but it is more likely going to take months at the moment
I will probably MOT the van at that stage and use it for a little bit just to cure the itch!
I will update tomorrow, hopefully!
View the Commer resto pics here: http://s786.photobucket.com/albums/yy149/bazil1972/
