Bit more progress:
With primer on the floor repair and seat box thingy:
As you can see the floor repair ribs aren't an exact match to the right of the repair as I had to make the repair section up at home over christmas 12 miles away from the van so I had nothing to keep trying it against, It's plenty good enough for the job it has to do though, being a floor under a carpet [8D]
Two rotten rear corners removed:
And some younger, fresher, fibreglassier (?) versions waiting to go on (Thanks again to Martin Maltas!!):
What lay beneath [:0] along with the first bit of good metal welded back in:
Opposite side also showing the repaired and filled number plate panel:
And finally, not much to look at, but here is the near-side of the van almost finished being prepped for primer (yes, I know, it isn't baremetal, but I have my reasons!)
It is getting closer, just the rear corners to finish and then the rest of the van to prep and it is ready for priming. Hoping for a van in time for the beginning of spring and hopefully an appearance at the welsh Commer meet in May.
And Comm-Mikal (?) I apologise about that DVD!!! [:0] I will try and figure out how to copy it tomorrow if I get chance and get your address off you. If you hear nothing, just send me a message to remind me.....head like a sieve.....
