Back of the garage
Now thats a thought I have not seen a streeeeeetched Commer
Everybody should have a Napier Sabre powered stretched Commer, its the only sensible thing to do :D
I'm beginning to wish we went out today as well - isn't scraping off old underseal a lovely job[xx(]
Swear - me[:0] I'm an honest, clean living, tea total pillar of the comunity. Believe that and you'll believe anything;)
Crawled out now and again to put a few coats of paint on the heater box I repaired, I've decided to put it back as it is,without the flap, and leave Harveys nose sealed up. The heater will just circulate the air in the cab - if I need any fresh air then I'll open a window:I Also made a little plate up to close off the hole I'd cut in the wheel arch to clear the SU dashpot. I came in earlier than usual cos I was frozen to the bone through lying on the floor - and that's inside the garage - probably because I wasn't enjoying myself as much as usual:I
we all get days where we not enjoying it so much...I also had a wire brush & painting session today and got really fed up with carp falling in my face...yes really cold today, despite being sunny
I knew it was time to go in today when the water I was washing parts in froze! Be thankful you have a garage, even if it's a cold one!!
Our house can get like that inside HAHAHA. The house is kind of two houses in one. We have an old stone part on the front and an 80's extension on the back. If i haven't lit the fire by 6.30pm i may aswell not bother at all as it takes ages to heat the place.
