I've been gathering bits and pieces over the last few weeks to get a few jobs sorted out. I decided that the steering box was in need of some love - it's been marking it's territory over the floor for a while now[xx(] I got a complete column and box from the guy at The Cambridge meet who brought the contents of his garage along for us to rummage through. It was a bit of a swine to change - a heavy lump to manoeuvre on you own as you have to change the whole lot out - steering column and box. The one I got was off a later Dodge but they're all the same I though - no - the mounting for the indicators is different
Commer
Dodge
I didn't want to use the Dodge indicator and cowl so a bit of adapting was required.
The shoulder at the top of the new collar is a bit too deep and the indicator assembly is sitting too low so I've just nipped into work to borrow the lathe again :I so that will be a job for tomorrow.
The belt driven water pump is redundant now I've fitted the Davies Craig so I sent it to Tim for some modification. He blanked off the bearing housing and the by-pass hose connection. The thermostat housing had been repaired with filler so a new one was required, but I also wanted a connection to fit a temperature switch for the lekky fan - only one thing for it...make one
The by-pass between the thermostat housing and the water pump is to allow some circulating through the engine before the thermostat opens, water from the head returns from before the thermostat to the suction side of the pump, but with the pump repositioned the by-pass wasn't by-passing anything and was just a stagnant flow, hence blanking the connection. However it's not wise to run the engine without any flow so the by-pass will be redirected to the suction of the new pump.
New housing and modded pump casing in place. Notice new switch for fan.
The by-pass from the thermostat housing will connect to the blue T piece at the bottom of the rad. When the heater eventually goes back in the return will be plumbed into here as well.
Tomorrow I'll finish off the indicator adaptor - and stick the piece of fascia panel back on I managed to smash off getting the column out:I
