Well I thought everything was going too well:I The installation of the EWP is straight forward enough and because I had moved the rad forward to make way for the lekky fan there was plenty of room. While the old pump is no longer required the body needs to remain in place it needs to be blanked off where the bearings and seal once was.
A blanking off kit
Trouble is it didn't work as the washer was too thin and buckled. I couldn't find anything thicker so I went a different way.
A rubber bung with a bolt through the middle - tighten the bolt - the bung expands and one blocked off water pump.
So not to dead-end the pump when the engine is cold a slight mod to the thermostat is required.
5mm hole
Everything bolted back on - system filled with water and the pump wired in and switch on. A gentle humming from the pump and the flow even through the small hole was quite impressive. The I noticed the drip, bugger, not coming from a hose but from the pump seal.
I ran the pump for about 20 minutes hoping that it would bed-in and again with the thermostat out - but no joy[V]
So much for my ebay bargain I've contacted the seller but not yet heard anything back.
Macker1 paid me a visit on Friday and we spent some time making up a few brake pipes with his pipe flaring kit - and a mighty fine job it made of them. Also sorted out a problem I had with my new clutch slave cylinder - the new one had a smaller hose connection so it was either buy a new cylinder, change the pipe or try something different:I
You know me - I did something different.
The pipe on the right is original size and on the left the smaller new cylinder connection.
Run a drill up the larger bore pipe and solder the two together and the old and the new are one.
So some small successes today - but one big bummer[xx(]
Harvey the RV
