I'm on a roll
Started off by cutting the bit I needed of the passenger side repair panel, as the rest of the frame was fine on that side, and tacked it in place.
Then spot welded a support plate to the back of the repair panel on the other side and attached the new lower frame using self tappers.
I punched a series of holes every few inches in the bottom flange of the lower frame then marked and drilled the matching flange on the top of the front panel. There was just enough room to get a screwdriver in to tighten them up and pull the two panels together[^]
Using a thin disc cutter the other end was mated up and joined together using a backing plated and self tappers again
I was a bit worried, as the new panel was a very tight fit, but I needn't have - everything pulled together perfectly so it was tacked in place.
After dressing up the welds a quick coat of primer was sprayed into the joint.
I'll spray some body colour into the joint as well before it's given a fillet of seam sealer. Just the edge of the dash top where it meets the frame to do then start tidying it up and paint
I even offered the screen up to the frame - it follows the curves perfectly[^]
