Back of the garage
looking wicked there mate :) i like the hinged flap as well :)
Time for a catch-up:)
I gave the cab carpet a good scrubbing, it's faded and a bit frayed around the edges but it looks better than the rubber mat. Also made a new speaker grille and got rid of the horrible modern things.
Re-fitted the door check straps after a clean and paint. They are normally spot welded in but I bolted them in instead as everything is nicely painted under there.
I had a go at making a little side table to match the trim in the cab, it fits in the clips for the main table and has a folding angle bracket underneath.
Bonnie did have a temperature gauge filling the hole in the dash but it was just plonked in and there was a plug where the sender should be. So I fitted one and wired it up (through the voltage stabiliser)
and it works - the temp rose steadily and stayed here[8D]
The ammeter is still just filling the hole though:I
Some new bling, nice stainless wipers and arms[8D]
and check out those new hubcaps:p
As well as all that lot I've done the brakes, the fronts look to have been done recently and the cylinders look new[^] The rears needed new shoes - also did an oil and filter change and gave the engine a good Gunking - ah the smell of Gunk drying on a hot engine[^]
The list of things to do has gotten very short - running out of excuses now;)
Summer's Coming
Looking great as usual mate. did you do away with the front speakers or just hide them[?] im going to be attempting to make door cards soon [^] now that the weather has finally picked up we can all crack on :p
Nah I got rid of them, the CD player blew up so I wanted rid - much rather have the old Motoroler working:)
Summer's Coming
This has reminded me about kick plates - mr Woolf can I have mine back or a new one from the pattern you made from mine?
That's the back gate, the portcullis and drawbridge will keep them out:)
The garage door is much worse:I
Summer's Coming
Thanks for the great comments chaps, the coachbuilt side of things still needs a bit of titivation but we're getting there:)
Summer's Coming
when you have run out of jobs you know where to find the colonel:D
good stuff mr panky [8D]
The Colonel Mustard
