I do like these CI conversion, their above cab styling is rather funky IMO. Plus you've got to love a converter who takes the original lower panels out wider
Not only do they take the lower panels out, but they re-create the Commer flutes. If I remember correctly, they used the same bodywork on Transits and Bedford CF's, retaining the Commer flutes. Just goes to prove which van is the Daddy!
Arnold will be getting some much needed top end work whilst I'm in Aus in June. I plan to (or attempt to)strip it down this weekend but will need a hand putting it back together and getting it tuned right. If anyone can point me in the direction of a good mechanic in the Cheshire area it would be much appreciated or if any Commer van fan would like to assist/lead(with reward)let me know. Will be in late June when it goes back together.
Yes all looks pretty good, ready for Tim to work his magic. Came apart easy too especially since I'm a pen pusher and havent touched the spanners in a while. Everything is bagged and labelled or taped and labelled so hopefully should go back together just as easy.
