6 speed gearbox conversion
Just discovered that this conversion won't work with an alloy head engine, unless you use the iron engine flywheel and pressure plate.
The 8 1/2 " Lexus clutch doesn't fit under the pressure plate [xx(]
Just remembered, they use a smaller clutch so the locating pins are on a different PCD:I
That's the problem. And the pressure plate is smaller diameter, so the plate won't fit under it :(
Luckily the flywheels are a straight swap, that's what I did with Harvey so I had the larger diameter clutch
Oh no!
Can you work any magic?
I guess you could always skim the face and re-drill the dowel and cover bolt positions:I
Still need a new clutch cover though
Not a problem, as a spare flywheel and pressure plate have been pressed into service :)
Can't re-drill it as they have turned the diameter down too small.
Another one done :p
Loving your work commeracer;)
2 more Lexus boxes getting victimised for the good of Commerkind :D
Excellent! Did you do the one for the car? Was it a Rapier or an Alpine.????
Yes, H120 and it was a great success :p
Excellent news.
I hope to be able to start getting my Vogue back on the road later this year. A 6 speed may feature at some point!
Hi interested in your conversion thread Commeracer .
The standard Holbay Rapier H120 has an 8 1/2 " clutch . How is this different to the Commer 8 1/2 unit ?
It's the same:) Just watch out for the splines on the input shaft as some of the early boxes had coarser ones.
Commerfest 2015 is happening. Contact me for details :)
No problem with the H120 clutch, but the standard Rapier/Alpine is smaller diameter :)
tim excellent work !! can you tell what the advantages are ....top speed better ....rev better ....acc. better ?
milage better ? I would like to know ....I'm still thinking about changing the engine all together with a matching transmission out of a newer Van or car ...but this might be the golden ticket ;)
