'76 Autosleeper
Originally posted by paulcloke
nice van mate, my su conversion is different to yours, mine comes straight up. does it generally run much better with the electric fuel pump
the leccie pump is ace. It means there is fuel in the float chamber when you first try to start the van, not after cranking for ages! Like I say I think I've mounted it too high so I may need to have a re-think
i thought they were gravity dependant, meant to go underneath close to the tank? i may be wrong but thats what i was told by someone when i had my sherpa
yeah that's right. I mounted mine on the little flat panel which goes from front to back and has the fuel pipe clipped to it. I think it was a bit too high, so I need to find somewhere else to mount it. Baz fitted his to the rear numberplate panel which would be ideal were it not for the fact that I'd be able to see the screws on the outside...
hmm, maybe mount it on a metal drop bracket so it will hang off the chassis rail?
yeah I think you're right. problem is it needs to be about 10" long to reach down to the bottom of the tank. I have plenty of pipe, clips and filters so I should be able to relocate it quite easily if I need to.
Wahay at last, I wondered what happened to Harvey's old manifold[8D]
Two's company
Something like this would be the ideal solution for you. it would be sturdy and the pump would be surrounded by the bracket so extra secure
picture is very basic but gives you the idea lol;)
Two's company
I know - it only took 3 years... and they say commers are slow...
would you like me to send you the original manifold back?
looks good to me. I'm a little scared about drilling holes in the chassis (it's just a thing with me) so I was considering using the tank mount screws. I'll have to work out where abouts to do it probably behind the axle...
If you still have it, Bonnies is looking a little suspect:I
Two's company
no problem! I'll try to sort them out this week
No rush, it's actually the exhaust manifold that looks dodgy:I but I'm planning on an SU conversion for Bonnie so it will come in handy.
Two's company
yeah if you can use existing holes it would be best but if you do drill it, give the holes a bit of aquasteal and paint in the edges of the holes, that way it should last years without rusting lol
Well done Rupert [^] it,s about time you got that fitted :I
I noticed the link tube on the carb seems to be open (that,s the big bronze spout nearest the engine next to the overflow pipe) and it should be blocked off or you will be sucking in a mass of air ;)
that could explain the problems tuning it - :I
what would I do without you guys?!
Oh dear [B)]
A short bit of pipe with a bolt pushed in the end tightly should work wonders ;)
I found this very useful:)
http://www.minimania.com/MM/SU_CARBS___Connection__HIF_type_763.htm
Two's company
