we have undertaken this repair many times now ,but i think the most promenant one which panky is on about was on the hunny resto. im sure someone will pull it up on here for you to see soon enough.
Hey Alan that's not a bad job at all. Grind the welds down with a flap disc and you will be surprised how much better things can look damn good for a first attempt too. It's not always about how good it is. It's more about that you tried
Totally agree, you should see some of my welding even after years of trying:I The one thing I would advise is to do away with the disposable CO2 cylinders and go for a reasonable sized re-fillable one and regulator. If you have a friendly contact in the pub trade then you will have a new best friend but I got mine from a local welding suppliers, it cost about £80 to get set up (and I know you'll find it cheaper elswhere) but I must have spent double that on those horrible little things from Halfords at a tenner each over the years[V] Now I don't have to worry about running out and a re-fill is £15 - for about 20 times the amount a disposable holds.
You're going to tell me you mate uses Argoshield now aren't you:I
