Which dizzy have I got
Hi All,
I am trying to find out which dizzy I have fitted to my 1968 Commer Motorhome (1725 engine).
Is it the 25D or 45D? Will it tell me somewhere on the dizzy itself?
Dave
Dave
Hello,
I think either can be fitted. 25D dizzys have long clips holding the cap on (around 3") and 45D have short ones (about 1 1/2") the points are different too. On a 25D the end of the spring is held by a nut, on a 45D its kinda loose and fitted with a little plastic shim.
And finally, 25D has a little spade connector for the low tension wire, on the 45D it comes via little rubber grommet through the Dizzy housing.
This website is pretty good for bits and might help with identifications.
http://morrisminorspares.co.uk/shop/index.php?cPath=790_791&osCsid=a5152b8c3d4d3afe9a4e491ccbe50b32
hope this help
Rupert
www.littleyellowcar.co.uk
I'm glad you asked that Dai, been meaning to find out with mine as want to order from speedys - many thanks bigmonkeyman, most helpful;)
Get some electronic ignition on them while your all lookin best thing i ever did fit and forget!!:D
nothing stamped on mine helpfully enough - have got electronic ignition on Bessie - old system so a bit rickety at times but when it works it works well:D
