BC Sunshine
The info that came with my Highwayman says it's 'empty weight' is 2040kg.
I have no idea if this is referring to actual dry weight or not, but what kind of weight limit should I be keeping in mind? I do have access to weigh scales along the highways if needed.
Unless I'm doing some really rough camping where I need to haul in water, I'm not planning on using the onboard water tank much (I'm not even sure of its capacity..).
I do live in a part of the world with some serious hills however.
How concerned should I be about weight distribution?
Fridge, stovetop, water tank, driver are all on same side.
Fuel tank, propane tanks are on the other.
