I doubt that. The water pump is at the front of the engine by the fan and the prop shaft joins the gearbox to the rear axle/differential......Well it would appear we have a waterpump leak at ,or around the prop shaft.
Ah! I didn't realise you were speaking in Americanese!Sorry, i forgot the language is a bit different. In the US prop shaft is a term for the propeller shaft in a water pump, and we usually call the gearbox /trans shaft a driveline or driveshaft. The front seal of my waterpump has a leak, i got a new waterpump this morning , hopefully theres no more surprises
