Van overall height?
Thinking about this ....... Whats the height of one ,without a f/glass roof? ,and with a roof? Please.
I have a sticker in mine that says 6' 11" (autosleeper)
Thats with the roof down, eitherway, i still have to take the Garage door off to get her home...
does it make much difference if you have 14" or 15" wheels [?]just remembering back as a kid,we often use to have to wait at a bridge,while the lorries in front let their tyres down,to clear the bridge,praying we wouldn't have a lorry in front :D
I was lucky, the previous owner of my house had put another set of double doors on the back of the garage and added a hinged flap above the front doors so he could push his caravan right through and store it out of the way :D. Plenty of room for Harvey (unless you want to use the cab doors). Obviously won't work for an up and over [V]
I converted my up and over (ooer!)door to hinged at the top ,so that when its open theres another 6 ft of dry area to work under if it rains(or even as a sunshade if Im very very lucky ! lol!)Got a pre-cast garage,so will have to jack the roof up and weld in some gap fillers all round!
What understanding neighbours you must have, mine would pass out with shock if they saw the crap I've hoarded in mine [:0](no not my motors before you start ;)).
Its quite heavy to lift the door up to horizontal,even tho' its thin aly.I then put 2 diagonal props from the outer corners to the bottom of the garage door posts.
Dont think I would be able to work on a van in there tho' as too narrow!Security isnt really a prob as the whole area is locked with heavy steel gates at night anyway.
I'm considering getting one ,but slowly running out of enthusiasm ,as I cant be a**sed to do lots of work on one ,even tho' Im able to overcome most probs.and the prices seem stupidly high to me ,for a road worthy one .Im not looking for one to use as a camper,as Id probably re-configure the interior any way.Got so much hoarded stuff around (so know the feeling Panky!!)Need to sell some of it to release a few quid. I dont 'do' e- bay tho'!The bigger the sheds you have the more room for cr*p!
Right .I need a proper answer to this now!! Need to know how high one of these beasts is WITHOUT the pop top,allowing for the natural curve in the roof,from side to side ! [8D]
olyslager manual,say's overall height 79.5"(80.75 inches on the pb model)my roof is max 8"high (measured at the centre back of van allowing 1" for the raised areas of the roof)hope this helps.
Measured my garage,need another 8" (oo er!) in height! So if I get one ,looks like a bit of serious suspension droppage is called for !
