tools you cant do without when restoring a commer
Originally posted by BigMonkeyMan
Originally posted by woolfy
i know of a hard job to do when restoring a commer, and you really need a proper tool for doing it. putting the little bloody clips onto the door weather strip, because when you wind the window right down the glass is just slightly still in the way, especially if you have pork sausages for fingers haha. and if you wind it right up its a really tight squeeze trying to shove your hand up inside the door through the little bloody door opening and getting to the correct position properly. there is a proper tool i think involved for doing this process, where you sit the clip into the tool and then slid it down inti the door from above, and then you have too pull it up hard to force the clips on. but i havent got one of these unfortunatly, so i have to persist with the other methods, haha.[V];):p
Big Bad Woolf
I managed it with an 8" strip of steel (about 1/2" wide) with the bottom 1/2" bent up. it worked really well. I just needed to pull the clips far enough up so they didn't fall off. Then I could wind up the window and push them all the way up. Only workfs if you have a flange to attach them to i.e. it;s not rusted off!
A spoon with the handle bent into 3 sides of a rectangle does this job fine
oh and dreams of commering ;)
in all seriousness (not the place for it I know!) in the dark winter nights there's nothing quite like daydreams of warm summmer evenings spent with your commer and your commer friends - got me through a few tough times I can tell you!
Mole grips, i use them all the time for keeping panels together whilst temp fitting, then welding. Got 8 of the things as well as some weird shaped ones to make sure everything is clamped tight!
Right angle magnetic clamps, great for placing on the roof, when you chuck tools up they stick in one place:I never actually used them for their proper use - keep forgetting I've got them:)
And relax
Right angle magnetic clamps, great for placing on the roof, when you chuck tools up they stick in one place never actually used them for their proper use - keep forgetting I've got them
That's because they're stuck up on your roof! :D
They're also great for holding panels flush when you are welding them in - just don't weld too close to them or the arc goes all funny!
(tools you cant do without when restoring a commer):)
Does this welder count?? >>
http://cgi.ebay.com.au/Commer-ex-army-GMC-mobile-stick-welder-/270640601681?pt=AU_Trucks_Commercial_Vehicles&hash=item3f036fda51
