Doug
Member
Hi folks
What are the correct spark plugs for the 1725cc engine, with cast iron head ? (ie .. completely standard)
Our van had NGK BP7ES ( think that's right - definitely a 7) but just as a test I've replaced them with new BP5ES (think that's right) from my Triumph 2500. He runs just fine but it's a hotter plug.. not sure what the significance of that is, but I'd like to replace with the right ones, so am just checking.
And furthermore ..
I'm used to SU carbs so the Zenith is a bit of a mystery at the moment. When starting, if I happen to flood the engine, a way of clearing it (with SU) is to run the engine on the starter for a bit with the accelerator right down. Flushes out excess fuel, eventually the mixture is right, and the car starts.
Would that work with the Zenith as well?
I've become a bit paranoid about starting the van as he misbehaved quite resoundingly over the last week; lying about having a good spark, flooding easily, using up loads oc Cold Start, giving the impression the battery is on the way out, etc. Naughty.
It turned out to be muck in the points gap giving an intermittent spark, now cleaned, so he's behaving now (I think) but I wanted to understand the carb more in case such naughtiness returns.
thanks all
Doug
And furthermore ..
thanks all
Doug
