latest update,
took the head off today - I think the photos are fairly obvious
I think I missed a bit of debris round the base of the stud prior to putting the new head gasket on - allowing a path between the cooling and cylinder 2 (and possibly a bit to cylinder 1) the rusty track is a dead give away
I also took the opportunity to check the fuel pump timing while the head was off.
for my pump the injection point on cylinder 1 is 2.75mm below top dead centre to get the timing marks on the fuel pump to line up. The pump was actually injecting 4.5 - 5.0 mm before top dead centre (too early) so I have adjusted that back within spec as well. Im not sure what effect injecting too soon has but putting it right can only improve things
The plan now is to give the block and head faces a bloody good clean, get a new head gasket and put it all back together again
The Dog is home....
my new business
The Dog is home....
my new business
