Looks fantastic that low! When you jack the rear up is it possible to change the rear tyre easily on the road side?
no mate not in the slightest bit easy..even with a flat tyre.im making longer rear shackles that will be adjustable and the lower bolt with be removable so you can just take the bolt out and have that bit extra room. Awkward as hell but worth it I reckon
How's about spring shackle mounts that are bolted through the chassis leg. With captive nuts welded to the mount and the bolt heads through to the floor area, undo the two bolts from above and the spring will swing free as you jack it up giving plenty of room to change the wheel. Use the same sized bolds as the wheel nuts and you could use the wheel brace to undo them
To help with changing the rear wheels, could you raise a section of the chassis next to the wheel and fabricate a section of outer fluted panel as spat which can be removed to access the wheel?
Have you tried it with using the commer jack rather than trolley? I can't change my wheels with a trolly but the commer jack points lifting the body before the suspension gives it enough space.. just
Yeh gave it a go and like you say ita a little bit more im not too worried about it at this stage.i wont be saying that when its peeing down and im at the side of a road somewhere im sure.
Dropped the tank today and took the original water tank and system out too.
got the other arch cut and also started having a play with the new exhaust position
