I snapped the spade end of the temperature sender when I caught the wire doing the brake stop switch[}
]. I have got a new sender from Speedys but now the temperature gauge goes off the scale at the hot end once the van is running (it probably takes 3 mins or so from cold to get there and then stays there)[B)].
I presume that this means I have the wrong temperature sender as the van has never had overheating problems before??
The van is a 1966 one so has the old dashboard with the Smiths gauge and the temperature sender has Smiths Accessories on it. There is some numbers on the nut but I can't read them but it looks like 102 oC. I can't see similar on the new one (it is intermotor). The nut on the new one was bigger but it looked the same and fitted easily.
Can any one help.
When running I am pretty sure the thermostat opens as the top radiator hose does warm up but the heater hoses are getting what feels like quite hot, could I have somehow buggered the thermostat changing the sender (I left the radiator cap on to stop it flowing back and the water level stayed in the sender housing....)
The main engine housing is getting hot but I dont really ever feel it so dont know if it is dangerously hot. I have tried running as long as I dare to see if the thermostat opens fully and the gauge drops as it may be the new sender is just very sensitive and the old thermostat isn't? but it doesn't drop.
If I need a different sender does anyone know where to get them from.
Please help we are going away at the Bank Holiday hopefully
Can any one help.
