SU Carb success
Originally posted by Gladys Crew
Originally posted by Panky
It sucks, it bangs, it blows:)
And add a little spark and you got the making if an internal combustion engine;)
Gladys & Bernie
Bernieeeeeeeeeeeee - that's the bang bit:I
Harvey & Bonnie
The BBG needle was a little weak for the Colonel, so a BFY was fitted 1/2 way to Yorkshire, which was a massive improvement and seems pretty close:)
Got my SU bought, refurbed to new, BDL needle which looms the same as the BFY Tim except a small blip at idle on the graph. Hoping will do,the job nicely. So defo will be seeing you soon gearbox donation in hand and a manifold int t'other :)
Hasta la supervista baby
Colin is running a BDL in Tigger and it seems too rich. I've taken the BFY out as it did seem too rich, but i had filed a flat on it from a previous set up. Now running a BAK but i have to re-seal the exhaust as it is blowing slightly, before any proper testing :)
Whatever do you want 145lb/ft of torque for ;):D
http://en.wikipedia.org/wiki/C20XE
The BAK seems closer, good for max acceleration, but a trifle rich in the lower gears on light throttle. I might try a BBV next :)
me me me :D
ill chuck the SU on and get the color tune kit out (then copy you anyhowz
One Carb To Rule Them All...Well it's only an SU but very shiny and new looking
See you soon Tim
[/URL]
