JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
I need a new or 2nd hand starter motor ...as far as I can see on the petly torn label is its a Lucas LRS 293 ..can anyone confirm this?
does anyone have one they would sell me?
I have a spare but it doesn't want to fit..its slightly different...I'll post a pic shortly
i have a spacevan one mate but i suspect its the same as your spare one:I[?]
[/IMG]
1980 perkins diesel spacevan
hers a pic of my lucas one which is longer than my spare..the length of the teeth on mine are 20mm and the other is 25mm
i will have a nose in a minute mate
wont be getting any pics though:I
[/IMG]
cheers Mark......heres the reason mine is kaput! ...I was tightening the nut that secures the power feed and it never got tight and snapped off[:0]
you can also see a small dark circle (middle left) there is the end of a cable which should have a female spade connector on it...this also broke off
!] partly my fault as i was so cross with it:I
mine looks like the bottom pic colin and has lrs 122 sticker on it and i measured the teeth at 18mm
[/IMG]
thats the bottom pic before you posted the other:I
[/IMG]
So, like my Lucas one......cool[8D] and if you can imagine mine pre damage, does the solonoid part look the same too mate?
this is the wrong one of mine..
all looks the same colin
[/IMG]
Cool...how much Mark? ...ohh, we'll do that bit in private lol i was going to say I'll give you £5 if you deliver it tommorrow as an Anniversary present hahaha
£5 and all i can eat at the bbq
and then we have a deal
[/IMG]
Done
[8D][8D]
i normally am[B)]:I
[/IMG]
