porf
0
Hi All,
Yesterday I swapped the plugs on the Dodge. She's not been driven yet and has been standing for a long while but has always started fine the last few weeks. Was supposed to be quick task out of the way.
After I swapped the plugs (like for like NGK BP6ES) I couldn't get her started. Turns over on the starter but no attempt as firing at all.
I checked for voltage on the +ve terminal of the coil and got various almost 0v readings. Should this be permanent +12v when the ignition is live?
I ran a straight +12v feed to the +ve terminal and she started and ran for a minute or so.
After this I tried again without the extra 12v feed and she started fine.
Since this point though she's back to totally refusing to start. Either with or without +12v to th e + terminal
With a plug out and against the engine I have sparks.
Which made we worry about fuel supply issues from where she's been standing. But with the fuel line removed from the carb she appears to be pumping fuel through fine.
With the fuel line on the carb there doesn't seem to be any fuel being pulled through.
Any ideas/suggestions?
Paul.
Paul.
