jimi
0
Have not used Commer for a while.
Bought new battery as couldn't start with crank handle.
Starter was always crud since I bought it and I want to know if it is dead if you can hear it click into the flywheel teeth but it is;
either turning really slow,
whining
or not moving at all.
I tried 2 batteries.
I put a cable from the negative battery terminal to the engine to check if bad earth.
I could also use some tips on starting from cold. Do you floor the throttle for a second or use choke?
I will get a tow soon to see if it will fire up and then if I need a new starter order one tomorrow.
whining
