Rust Killer
admin 2.0
I've been using Aquasteel for ages and it does a great job of halting the rust - but it's rubbish on the bodywork you can see as it will eventually lift a skim of filler put over it. Now some of you probably already now this other stuff I've just found but I thought I'd share my experience.
The Mini guys love this stuff and highly recommend it
I did a little trial today on an awkward bit on the Mini - the rear wheel arch to body joint.
After a wire brushing and de-grease.
Deox Gel splurged on
Left for an hour then wire brushed and washed down
Not the best of pictures but it has eaten most of the rust away and dull grey metal can be seen instead of rust but there is a bit of flash corrosion starting already. I'll give it another dose tomorrow just to be sure.
Another good thing about it is that it doesn't appear to damage the paint - the wire brush does though:rolleyes:
There's a couple of bits on the bodywork that need doing so I'll report back when I do them.
Wow ! Itried a similar thingwith jenolite grl .. didnt seem to do anything.
the jenolite solution is fab though.
i like to use kurust for rust repairs- seems to behave quite well ☺
I remember seeing this stuff a few years ago and people raving about it. completely forgot about it. Thanks for the thread!!
Will have to get a tub for the remainder of my door repairs.
It's a different type of product. Aquasteel is a rust converter and is great for those awkward to get or large areas of surface rust that don't need a good finish, the Deox gel removes the rust so it can be primed and a skim of filler over it before paint. It takes a bit of time and effort to get good results but from various reports I've heard it's well worth it.
