Weekend before last I finally got round to welding the floor on Bertie (the Punto Cabrio). I disconnected the battery while welding and reconnected it the following day. While the car was raised I thought I would check the exhaust for leaks, but when I started it seemed to be only running on 3 cylinders. I thought this might be due to damp weather, so left it while I put the interior back. When I started it to move off the ramps it appeared to be only running on one cylinder and unable to move under its own power. I left it a couple of days to make sure it was entirely dry, but it would still not run. I had a spark, a pulse at the injectors and the fuel pump was working. Just to check, I replaced the ECU, coil and crank sensor, but it made no difference (I have since put originals back). It would try to fire, but only seem to catch on one cylinder. I checked the plugs and they seemed a bit sooty.
Couple of days later, we went to look at a new car and when we got home I tried him again. This time he started and seemed to run on 3 cylinders, then all 4. I gave him a good run and he seems ok. On Friday I drove him from Suffolk to Lincolnshire and back and he drove like a train, pulling smoothly from 60 in 5th on hills (A1 at Stamford), leaving the lad in the Fiesta on my boot in the distance. The sparkplugs are now a nice biscuit colour.
Could it have been caused by a blockage in the exhaust? I think the back box is disintegrating internally as it rattling, despite being securely mounted.
All sensible suggestions welcomed and silly suggestions appreciated!
