Overdrive prop shafts
To help finance the brand new one I've had made..................
One coarse spline overdrive prop shaft. Brand new front sleeve, good UJs. No play. £60
One fine spline overdrive prop shaft. Useable (we used it all last summer and it was fine) but front sleeve surface is a bit rough and leaks oil very slightly. Both UJs have slight play in the yokes on the centre section. £20
