one more for the fleet
Originally posted by transitvanman
had a problem today its running well rich and it wont tick over[:(!]
missed this one in all the excitement - did you figure out what problem was?
interested to know as mine does this sometimes - have weird electronic ignition system on my van which only does it on certain days - am starting to wonder if vans can get hayfever:I
fitted a weber carb it runs nice but when yoy switch it off petrol drips out the end of the throttle shaft cant see why took it to the local weber dealer and he dont know eather the carb all checks out ok[:(!]
today i was on the m25 near the a2 exit and i looked at the speed on the satnav and i was doing 78mph[:0]
also got a new grill and dash panel:D
just fitted two new window chanels to the drivers door window dont rattle now git to do mind[8D]
Where did you get the chanels from [?]
i have a bit of a problem with the petrol running back to tank and it takes ages for it to pump up agen think my pump is on its way out ?[xx(]
sounds possible, they're not up to any high pressure action at the best of times - more of a steady trickle :D
There are some threads dotted about regarding electric pumps which might be interesting :)
Ive got this problem on my camper its the fuel vapourising in the carb because of the heat it gets wel hot under that little enging lid!Im goin to fit an electric pump so when you turn the ignition on the fuel is back there instantly and will start straight away:D:);)
when are we going to see a few more up to date pictures of your panel van, mr transitvan man, you promised ages ago that you would show us a few new pics, pleeease;):p
is this one any good [?]
http://cgi.ebay.co.uk/COMMER-HILLMAN-SUNBEAM-1725-FORD-PETROL-PUMP_W0QQitemZ380065357906QQihZ025QQcategoryZ9903QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Fit an electric one like a facet and a filter king reg it wont give you any trouble then just make a plate and a gasket forthe hole in the block where the pump goes might even give her a bit more poke!!:D:D
http://cgi.ebay.co.uk/Facet-Fuel-Pump-Brisca-Kitcar-Autograss_W0QQitemZ370087326306QQihZ024QQcategoryZ100921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/FILTER-KING-FUEL-PRESSURE-REGULATOR_W0QQitemZ190253673171QQihZ009QQcategoryZ122139QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
ok i am done racing for the year so will have a bit more thim on my hands i need a prop so i can cut it down to fit my overdrive box anyone got one???
