stable
0
Hello,
So about to do a good distance in Charlie.
I have a little problem - the dip stick collar is floating about on the shaft so it is less than accurate.
I thought draining the oil and putting the correct amount in then re calibrating the sleeve on the stick would be best but could anyone confirm the capacity when at the correct level on the 1725cc engine?
many thanks,
Tom
many thanks,
Tom
