Non Runner
Hi All,
I was hoping to make it to Gaydon again this year but it looks unlikely now. Had a few issues with the van which are slowly getting sorted. Now I have a problem that the van will start easily but as soon as you push the choke in she cuts out and will only start again on the choke even when warm. I have had the carb off and checked all the jets, the diaphams, and changed the filter. there is plenty of fuel getting to the carb so the electric pump is working ok. Cannot think what else to try, it certainly sounds like fuel to me. Any thoughts would be much appreciated.
Anybody going to Gaydon I hope you have a good day with less showers than last year.
Thanks again for any input. Malcolm.
That's a bit of a bummer. Is it the original type carb? if so al I can suggest is the palm of the hand carb unblocker method. Start the engine with the carb elbow removed, rev the engine and slap you palm over the inlet. It certainly does suck hard so be prepared. There might be a tiny bit of debris in there somewhere and this method has been known to clear it. Alternatively it could be the dreaded snakeskin blocking the fuel line.
Good luck
Thanks Panky. I am running on the Weber carb, so I will try your hand carb unblocker method and see what that does. I had the snakeskin problem sorted when I put the van back on the road so that should not be an issue. There is plenty of fuel flow at the carb, so no blockage from the tank to carb.
Thanks again.
Tried the hand carb unblocker, no success. Changed the carb for a spare but no improvement, so I am now doubting it is carb trouble. Our mechanic is coming on Tuesday so will see what he finds.
Thanks again for your input, will keep you posted of developements.
I know you changed the carb but have you tried turning the tick over up a bit.
Problem solved but you are not going to believe it. I was there and I don't believe it. Our mechanic came on Tuesday and we started up and the problem persisted. He had a thought and a look and a listen and said I can hear something. First we thought a leak on a gasket and then a faulty idle mixture screw but it turned out that the blanking plug just above the screw was missing (the carb has been on for about 18 months). He put his thumb over the hole and the van ran with no problems. Fortunately I had an old spare carb and he managed to get the blanking plug out without damage and fit it to the existing carb with some epoxy to make sure of a good seal and to stop it coming out again. What are the chances of that. At least that is one job off the list.
Thanks again for your advice and help. Malcolm.
