New project
OK good find but is it off an Arrows series or an older model? If it's the older type then it will bolt straight on to the engine:) Things to check are the splines on the input and output shafts, some are fine splines, some are coarse splines or even one of each either end. Not a problem on the input you just use the correct clutch plate but if the out put different to your current prop shaft then you will need to find one that matches - the prop will need to be shortened too as the OD box is longer.
If the other box you've found is a J type then then the housing should fit the one you've got whether it's an Arrows one or not.
J type I fitted to Harvey
This link might be of use during your re-build
http://www.buckeyetriumphs.org/technical/jod/JOD1/JOD1.htm
No Commers aren't over priced - they're just catching up with definitely inflated inferior vehicles;)
Please do and please give us a blow by blow account as it's not been shown on here before so lots of pics and progress please - for the interest and benefit of us all. Never had an OD apart myself but I've heard it's not as difficult as you might think:)
