Need new battery
Iv given up on our old battery and need a new one. Whats the best kind to get and does anyone know a good supplier. Buttercup now sitting in the supermarket car park full of beer and going no where.
http://forum.commervanfan.co.uk/topic.asp?TOPIC_ID=6428&SearchTerms=battery
just did a quick search ....
buy the best you can afford hope this helps
The Colonel Mustard
As long as it fits in the hole and the connections are the right way round it'll do, but get the best cranking power you can.
Summer's Coming
These are about the best on the market http://www.ebay.co.uk/itm/Optima-Red-Top-Starter-Battery-RT-U-4-2-8004-250-/161066412421?pt=UK_Cars_Parts_Vehicles_Other_Vehicle_Parts_Accessories_ET&hash=item25804e6985
Thats a spiral battery fitted to a lot of the chrysler range (eg pt cruiser etc) and jeep models. They are for the more modern charging system I would say so just go for 096 or a 100 these are uk battery ref numbers so any motor factors will be able to sort you out with one.
http://www.ebay.co.uk/itm/EXIDE-096-CAR-BATTERY-ALFA-ROMEO-AUDI-BMW-HONDA-NISSAN-PEUGEOT-RENAULT-PORSCHE-/271200644881?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f24d16f11
Or you could go with a cheaper one lion batteries are euro car parts own brand and are made by exide so pop down your local branch
http://www.ebay.co.uk/itm/FORD-TRANSIT-DIESEL-CAR-BATTERY-096-100-12V-HEAVY-DUTY-SEALED-2-0-2-4-TD-TDCI-/290755378315?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43b25efc8b
JON'S AUTOS the garage that comes to you...
[email protected]
www.jonsautos.co.uk
ere Jon show us yer Transit pics! Would love to see the full set-up and livery! is it the very same one you restored?
Yeh its the same one I restored there are two pics on "the transit mk5" in other projects. Its got an on board compressed air system that I designed and runs off the engine by means of a belt and an air con clutch. It takes 2mins 15seconds to produce 8bar of pressure on engine idle, and maintains it so you can run an air cut off tool;)(which use loads of air) If you increase the rpm of the engine you can half the time it takes to get to 8bar:D Its also got an on board 110/240v generator that runs off the engine and doubles up as a welder!
Ive racked it out with bott racking and fitted a rapid deployment trailer as well for the ones you cant fix straight away;)
Started work on my mk2 transit now its rotten! or should i say it was;)
[email protected]
www.jonsautos.co.uk
