Karrier Bantam Fun
The Karrier is using a litre of oil with every tankful of diesel.........................time to have a look at the engine I think.
First though, the cab mats were a disgrace, so I bought some chequer plate style rubber matting and made some nice new mats while the seats were out.
Might even get the drivers seat reupholstered while I'm at it.
This could even turn into a bit of a makeover. Hmmmm.
The Karrier was cunningly designed with a cab floor that completely dismantles so the engine could be fully reconditioned while still in place. Just as well, as getting it out is going to be, shall we say, interesting.
The grille comes off easily enough, except that two of the fixings are behind the cab heater and the electrics panel.
After a stormy night, the sun came beating through the windows, upsetting the camera.
Out with the radiator.
If only it was this easy to get at the fan belt with the radiator in place. Anything to do with the alternator normally has to be done lying underneath with the blood draining out of your arms.
Then all the peripheral bits came off.
The engine is a bit tall to get out from underneath without jacking the truck up a long way, so it's easier to remove the head in situ, and also make the engine lighter. It is a big old lump.
So, "orf with his head".
I like the idea of having the cam followers in the head. They are all in good nick and showing no wear or pitting, as is the cam which is right at the top of the block.
Next job was to pull all the head studs.
Locking nuts are all very well, but most of the studs still needed more effort from a big pair of Stillsons. Yes I know, stillsons damage the studs, but so does doing locking nuts up too tight and stretching the threads, so the lesser of the two evils is a few teethmarks on the studs.
You can see increasing amounts of oiliness in the bores from left to right in the next photo.
So it is fairly obvious where my oil consumption problem was coming from.
Then in with the crane.
The idea was simple. Unbolt the mounts and bellhousing, pull the engine forward as far as it would go, then lower it gently to the floor.............................if only it was that easy. I misjudged the thickness of the flywheel and clutch together, (it's about 6 inches!) so with the engine smack against the front crossmember, it was still about half an inch too tight to drop the engine. With the engine hanging on the crane, and the gearbox input shaft entangled with the clutch, I couldn't go back, so in the end I settled for removing the clutch cover working through the gap, then tying it up inside the bellhousing so I could drop the engine. Not fun at all!
I can't put it back using that method, so the gearbox will have to be moved back a couple of inches to make room.
So finally, the lump was out on a piece of ply on pipe rollers, and easy to roll out from underneath the truck.
The lifting bar is the kind I make for most of my engine lifts. It bolts into two head stud holes, and has several holes for the shackle so I can get the "angle of the dangle" of the engine just right. Very important for lining it up easily. That engine's built like a brick privy for a lifetime's service. At 55bhp, it's the same(ish) power output as the 4108 in the camper, but with nearly twice the cubic capacity and governed at 2600RPM, it has masses of grunt.
In the next exciting episode, we should get to see inside, and find out why there's all that oil in the bores.
Managed another day on the engine today.
Stripped the head.
Not too bad. A bit of play in the exhaust valves, but the inlets are spot on. I'll leave them I think.
There's a lot of fixings in the timing cover!
So I made some holes in a bit of card, so I can remember where to put them back.
This is what's inside the timing cover. It is why these engines don't break down, and why I like them.
Now that ain't going to break any time soon! Cam:top left. Injection pump:top right. Vacuum pump: small one on the right. The other two are idlers.
Anyway, all dismantled, and all parts pressure washed, kerosene washed, and pressure washed again.
Nice to have a couple of piles of clean parts (and an oily lawn!)
A rebuild kit has been ordered, and the block has been booked in at the specialist for pressing in the new liners.
I'll also get them to do the small ends and cam bearings while I'm at it.
That will be next week's fun.
my father in law has one of these in one of the barns, stores grain in the back, fires it up once or twice a year and never fails...doesnt have fill up with smoke though :)
It was 1992 when I bought and restored the truck originally, and it's had plenty of time to get dirty since then. What with 25 years of road dirt and the engine breathing loads of black oil out of the filler cap, it had got in a right old mess under the engine cover. I needed a way to get it all clean. I needed a steam cleaner!
Whenever we are likely to be going anywhere, I try to look on a certain internet auction site to see if anything on my "goodies" wishlist is for sale somewhere en route to where we will be going, if you get my meaning. Came up trumps this time with a "spares or repair" industrial steam cleaner for £45 about twelve miles from yesterday's destination.
Nothing wrong with it, just as long as I keep it properly tested. So dismantled, cleaned up, pressure tested and WORKING! It delivers 95C water at 90PSI which presumably melts the goo and blows it away.
There's a chassis leg that I tried it out on. Only took seconds to do that bit. It uses a small amount of water that I can catch in drip trays inside the workshop. It won't touch 45 year old caked-on grease though.
I'll use it to do the engine bay before I put the engine back in, then take the truck outside to do the rest. That's a job I've been putting off for years.
I've also fitted seat belts. That's quite a job in a cab that was designed before anyone thought of putting in mounting points. Pictures later when I put the interior back in.
While I was doing all that the engine parts turned up..................
Now even Sally agrees with me that a new piston is a thing of beauty.
The relined engine block should be back from the engineers at the end of the week, so I can get on with the rebuild.
Meanwhile, I'll be shifting the gearbox, and trying to find/make some replacement mounts, as they are well shot, and make reversing a very juddery experience.
The fun continues.................
Today I picked up the relined block and the con rods with the new small ends. The engine was fine but the small end bearings had 3.5thou clearance. Specialist said he hadn't reamed them and the bushes came like that. No way I'm fitting them.
I got on to the parts supplier, who got back to me within the hour. His whole batch of small end bushes were bad, and his new supplier had held up his hands straight away. He'd order a new batch from his old supplier and send me some replacements.
If it was easy, everybody would be doing it wouldn't they?
The 'specialist' should have known better and should not have sent them out to you in the first place:mad: You're doing their work for them and dashed good work it is too:cool:
